Inter AS MPLS VPN
Apr 20th, 2009
  • Bronze, 100 points or more
Dear experts ,
We are planning to interconnect our MPLS with one of the other provider in Europe .
There is no MPLS support between us and the provider and there is no diarect connectivity . I'm planning to establish the MPLS BGP with other provider and sharing some MPLS VPN routes .
What are the best ways to do it ?
In my case can I establish the MBGP connection with my loopack IP ?
Haris
Overall Rating: 3.5 (2 ratings)
Giuseppe Larosa Mon, 04/20/2009 - 11:03
  • Hall of Fame,
    Founding Member
Hello Haris,
Without direct connectivity I think you need to use some form of GRE tunneling between you and the other provider.
the GRE tunnel provides you a logical MPLS link between you and the other provider.
Other solutions are possible.
Hope to help
Giuseppe
