Frame relay question
John Blakley
All,
I have a test lab configured in gns3 for frame-relay, and I had the following question.
I configured frame relay on both router's physical interfaces, but I couldn't ping either one. I then changed the physical interface to only encapsulate frame-relay and then I created subinterfaces for point-to-point connections. I could then ping each router.
My question is, when is it appropriate to use the "frame-relay map ip" command? I tried this command on the physical interface before creating my subinterfaces and it didn't work.
John
HTH, John *** Please rate all useful posts ***
23 Replies 23
Giuseppe Larosa
Hello John,
frame-relay map ip is useful for point-to-multipoint subinterfaces and physical interfaces in the following scenarios:
(one of more of the following can apply)
a) you don't want to rely on inverse-ARP
b) you need to run routing protocols that use multicast discovery so you use
frame-rel map ip remote-ip local-dlci-to-remote-ip broadcast
broadcast keyword
c) you haven't a full mesh but an hub and spoke and you need to add an additional
frame-relay map ip other-spoke-ipaddr dlci_to_hub
in order to ping from spoke to spoke on wan interfaces
It should have worked also with physical interfaces: notice that if you have emulated a back to back connection the dlci cannot change at the two ends
Hope to help
Giuseppe
Giuseppe,
What do you mean by this:
"notice that if you have emulated a back to back connection the dlci cannot change at the two ends"?
What I had configured is "something" like this:
RTRA:
int s0/0
encaps frame-relay
frame-relay interface-dlci 100
frame-relay map ip 192.168.1.2 101 broadcast
(I also tried frame-relay local-dlci 100)
RTRB:
int s0/0
ip address 192.168.1.2 255.255.255.0
encaps frame-relay
frame-relay interface-dlci 101
frame-relay map ip 192.168.1.1 100 broadcast
I was unable to ping from either router. I took the same config and placed it under a subinterface as p2p, and it worked fine. This was all virtual though (using gns3), so I'm not sure how accurate it is. I also tried to put on one router "frame-relay intf-type dce" to emulate the dce side of the connection, but that didn't work either =)
Thanks!
John
John
GNS3 is accurate, it's just a GUI front-end for dynamips.
What Giuseppe was referring to was the difference between 2 routers
1) connected directly together via a serial link
2) each router connected to a frame-relay switch, which is an option in dynamips.
You could always post the GNS3 .net file and i could load it up and have a look.
Jon
Hello John,
unless you have configured a router to act as a FR switch the DLCI is the same.
if you have a FR switch the situation can be:
RA -- DLCI 101 -- FR switch --- DLCI 100
there is no concept of local DLCI : DLCI is always local on each interface to FR switch link.
so for the scenario above
RA
int ser0/0
frame-rel map ip 192.168.1.2 100 broadcast
RB
int ser0/0
frame-rel map ip 192.168.1.1 101 broadcast
this is all you need.
frame-relay interface-dlci is usually used with point-to-point subinterfaces.
Hope to help
Giuseppe
andrew.prince
Level 10
Level 10
John,
Rememeber you have to link the layer 2 (Frame Relay) to the layer 3 (IP)
Without "frame-relay map ip" how will the device to know what layer 2 needs to bew binded to what layer 3?
It would be appropriate to use it on point-multipoint, or when you have not configured a specific interface for a specific DLCI, alsi if you do not have address space available for the WAN to be a whole /24
HTH>
Edison Ortiz
Hi John,
Frame-Relay networks are non-broadcast in nature and they need Layer2 to Layer3 mapping for IP connectivity.
When you use the frame-relay map ip you are performing a static mapping but if you want long enough while the interface are up/up, you will also get dynamic mappings from the Frame-Relay switch. Frame-Relay relies on inverse-arp (enabled by default) for dynamic mappings but this process can be delayed so the fastest way to get connectivity is to use static mappings.
You mentioned the static mappings didn't work, care to post the sample config along with the show frame pvc output?
HTH,
__
Edison.
Edison,
This was all virtual in gns3. I'll get the output tonight when I'm playing with it again, and I'll post the output tomorrow.
Thanks!
John
John,
Yes, you said GNS3 at the beginning and that's why I said if you wait long enough.
Now, I created a little lab on GNS3 with a FRSW (provided by GNS3) along with 2 3600 routers.
On the FRSW, I create the following mapping:
Port 1
DLCI 101
Port 2
DLCI 201
Port 2 is connected to R1
Port 1 is connected to R0
Looking at R1 show frame pvc output is showing DLCI 201:
PVC Statistics for interface Serial0/0 (Frame Relay DTE)
Active Inactive Deleted Static
Local 0 0 0 0
Switched 0 0 0 0
Unused 0 1 0 0
DLCI = 201, DLCI USAGE = UNUSED, PVC STATUS = INACTIVE, INTERFACE = Serial0/0
This information is being sent from the FRSW.
On R0, I see DLCI 101
Local 0 0 0 0
Switched 0 0 0 0
Unused 0 1 0 0
DLCI = 101, DLCI USAGE = UNUSED, PVC STATUS = INACTIVE, INTERFACE = Serial0/0
If I wait long enough, both PVCs will be ACTIVE and I will have mappings thus the ability to ping will be there.
R0 is now ACTIVE:
Local 1 0 0 0
Switched 0 0 0 0
Unused 0 0 0 0
DLCI = 101, DLCI USAGE = LOCAL, PVC STATUS = ACTIVE, INTERFACE = Serial0/0
R1 is also ACTIVE:
Local 1 0 0 0
Switched 0 0 0 0
Unused 0 0 0 0
And you can see the mapping:
R0#sh frame map
Serial0/0 (up): ip 192.168.12.2 dlci 201(0xC9,0x3090), dynamic,
broadcast,, status defined, active
R1#sh frame map
Serial0/0 (up): ip 192.168.12.1 dlci 101(0x65,0x1850), dynamic,
And ping across:
R1#ping 192.168.12.1
Sending 5, 100-byte ICMP Echos to 192.168.12.1, timeout is 2 seconds:
R0#ping 192.168.12.2
Sending 5, 100-byte ICMP Echos to 192.168.12.2, timeout is 2 seconds:
Now, if you are referring to the fact that you can't ping the interface itself, well - that's a different story and you have to create a static mapping pointing to a remote DLCI for this to work.
BTW, here is the portion of the config:
R1#sh run int s0/0
Building configuration...
Current configuration : 117 bytes
interface Serial0/0
ip address 192.168.12.2 255.255.255.0
encapsulation frame-relay
serial restart-delay 0
end
R0#sh run int s0/0
interface Serial0/0
ip address 192.168.12.1 255.255.255.0
That's awesome Edison! I could get the routers to see each other creating the dlci through the frame switch that gns provides. I wanted to see the "frame-relay map" in action, and that's what I couldn't get to work.
Thanks!
John
John,
Well, tonight - be sure to post the show frame pvc and identify what each side is seeing.
Dynamic mapping can be painful a times and a reboot may be required. Static mappings works right away and from my example, R1 static mapping would be like:
frame map ip 192.168.12.1 dlci 101
and R0
frame map ip 192.168.12.2 dlci 201
Okay,
My pvcs came up, and I see what you mean about how it will learn the mapping from the switch. I couldn't get R1 to see R2 because it wasn't in the mapping (sh frame-relay map), so I tried to manually map it and it still didn't work.
Here's the topology (gns3 file), and the configs that I created.
R0 can see R1 and R2
R2 can see R0 but not R1
R1 can see R0 but not R2
I couldn't map more dlcis in the switch because they said they were already mapped. The dlci config on the FRSw looks like:
1:101 2:201
1:102 3:202
(or something like that). I could map 2:201 -> 3:202 or vice-versa.
Also, I can't get ospf to run between R1 and R0, but R0 and R2 work fine.
Thanks!
John
And here's the last one.
Thanks!
John
John,
Your FRSW portion isn't complete. You need 2 PVCs for each spoke.
Here is my FRSW portion:
[[FRSW FR1]]
1:102 = 2:201
1:103 = 3:301
2:201 = 1:102
2:203 = 3:302
3:301 = 1:103
3:302 = 2:203
And I'm getting mappings:
R0#sh frame map
Serial0/0 (up): ip 192.168.123.2 dlci 102(0x66,0x1860), dynamic,
Serial0/0 (up): ip 192.168.123.3 dlci 103(0x67,0x1870), dynamic,
R1#sh frame map
Serial0/0 (up): ip 192.168.123.1 dlci 201(0xC9,0x3090), dynamic,
Serial0/0 (up): ip 192.168.123.3 dlci 203(0xCB,0x30B0), dynamic,
R2#sh frame map
Serial0/0 (up): ip 192.168.123.1 dlci 301(0x12D,0x48D0), dynamic,
Serial0/0 (up): ip 192.168.123.2 dlci 302(0x12E,0x48E0), dynamic,
BTW, don't use frame-relay interface-dlci under the main interface. This command is intended for DLCI allocation in subinterfaces.
http://www.cisco.com/en/US/docs/ios/wan/command/reference/wan_f1.html#wp1015008
HTH,
__
Edison.
Thanks Edison! I'll try your suggestions tonight. I created the mappings in gns3, and for some reason it kept telling me that the addresses were already mapped, which they weren't. I'll manually edit the file and see what happens.
Is there a way to keep FR routers from learning the mapping from the switch? I'd like to see how the frame-relay map ip statement works. Thank you for the link too. :)
Thanks!
John
