ACE deploying issue,
Apr 20th, 2009
I have question in regards to Deploying configurations to ACE with ANM. I presume it should deploy it in few seconds but for me it takes 8 to 10 minutes. Can anyone suggest why is this taking so much time????
Thanks in advance.
dario.didio Tue, 04/21/2009 - 05:56
  • Silver, 250 points or more
Do you have a large config? How many contexts?
Is there an issue with the connection between the ANM server and the ACE (low bandwidth,...)
Did you install the ANM on an approved server (meets the min requirements?)
ACE is well discovered by ANM?
Keep us posted.
sumaiyausa Tue, 04/21/2009 - 06:20
Hi Dario,
Thanks for the interest on this query.
Please find the answer below:-
1) not much big config. 5 to 6 context.
2)No issues between the ANM server and ACE.
3)yes installed on approved server.
4)yes.
dario.didio Tue, 04/21/2009 - 06:39
Do you have problems when configuring the ACE via CLI?
sumaiyausa Tue, 04/21/2009 - 07:46
No problems but when we sync the data from anm the ace gets crashed.
