Warning message
Call Handler
Apr 20th, 2009
when a person calls a Switchboard Number: 02088770357 they get an option and when it say "If you know the extension please enter it now" if you enter the extension of the person you are trying to contact it goes straight to voicemail instead of ringing first and if no one picks up the phone then it should go to voicemail. I tried it with extension 541 which is the extension for John.
Need help to resolve this issue.
Jaime Valencia Mon, 04/20/2009 - 07:15
  • Cisco Employee,
  • Hall of Fame,
    2011
configure under transfer options to ring the phone and not to go directly to VM, this is on the subscriber
java
if this helps, please rate
