7911 phone ...CUCM 6.1.1.3108-1 ... Config question
Answered Question
Apr 20th, 2009
I have a user who needs to have a speaker phone function. While the calls come over the speaker, she can't speak unless she lifts the handset.
I tried using a Plantronics headset but that doesn't work.
Is there something I can configure in CUCM for this device to make the speaker function or the headset work?
Donna
Correct Answer by Rob Huffman about 7 years 11 months ago
Hey Donna,
Great work my friend! There are alot of bits and pieces to check when using the 791x with M12 for sure ;-)
Cheers!
Rob
Overall Rating: 5 (2 ratings)
Rob Huffman Mon, 04/20/2009 - 07:54
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Donna,
Sadly the 7911 Series does not have Speakerphone or "built-in" Headset capabilities. There is a Speaker (for on-hook dialing) but no Micrphone :(
Because the 7911G does not have built-in headset capabilities (no headset amplifier or headset button) like the 794x/796x/797x series, the handset must be off hook to connect the audio stream.
For the 7911 you will need to use the setup with the Plantronics M12- Amplifier Kit and chosen headset. For models like the 7911 the M12 has to plug into the Handset Jack and then the Handset Cord plugs into the M12. If you must use the M12 you may need to adjust the Phone/Compatability setting slide (located under door on Left-Hand side of the M12).
http://plantronics.custhelp.com/cgi-bin/plantronics.cfg/php/enduser/std_adp.php?p_faqid=9531&p_created=1202876439
If you are going for something like the CS55 or CS70 (Cordless) headset, you will be good to go without the M12 Amplifier
Hope this helps!
Rob
donnaavila Mon, 04/20/2009 - 07:57
Hi Rob,
Thank you. I am sure this will help.
I appreciate your assistance again :-)
donnaavila Fri, 04/24/2009 - 05:29
Hi again...
I have the M12 adapter with Plantronics headset and for some reason it doesn't work.
Any other suggestions?
Donna
Rob Huffman Fri, 04/24/2009 - 05:39
  • Hall of Fame,
    Founding Member
Hi Donna,
I just set one up on a 7912 to test (sorry no 7911 in the lab :)
Check the following;
Batteries inserted properly
Cords plugged into proper locations
Handset "off hook"
Headset button on M12 engaged (should show Green)
Compatability slider on M12 set to 5
Can you try these and let us know :)
Cheers!
Rob
donnaavila Fri, 04/24/2009 - 07:29
Hi Rob,
After changing out batteries, power supplies, faulty headsets, LOL...It finally works. Thanks for your support!!! Your the best!!!
Correct Answer
Rob Huffman Fri, 04/24/2009 - 07:34
  • Hall of Fame,
    Founding Member
Hey Donna,
Cheers!
Rob
