Does CiscoWorks LMS 2.6 have an open API???
Apr 20th, 2009
Does CiscoWorks LMS 2.6 have an open API I can access? Or do I need to use the CLI? I want to try to pull out configs from RME.
Joe Clarke Mon, 04/20/2009 - 07:41
There are some API components to LMS. they come in the form of servlet access. Exactly what kind of information do you want to retrieve programmatically?
Marvin Rhoads Mon, 04/20/2009 - 07:44
If you only want current configs, look at the shadow directory. RME stores text copies of the current configs there.
The shadow directory is located in /var/adm/CSCOpx/files/rme/dcma on Solaris and NMSROOT\files\rme\dmca on Windows.
