Setup VPN on 877
Apr 20th, 2009
I have a 877 Router with software version 12.4(15)T7. We have several users that want to VPN into site. Can you point me to a doc that explains how to setup the VPN on the 877 Router?
I have a telnet connection to the 877 and therefore, will need to perform work over CLI instead of SDM.
gadgroupllc Mon, 04/20/2009 - 13:09
I've created the config. However, I get Invalid SPI size (PayloadNotify:116) error on vpn client.
here is config:
mhsrtr#sh runn
Building configuration...
Current configuration : 6198 bytes
! Last configuration change at 15:54:03 CDT Mon Apr 20 2009 by admin
version 12.4
no service pad
hostname mhsrtr
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
aaa new-model
aaa authentication login rtr-remote local
aaa session-id common
clock timezone CST -6
clock summer-time CDT recurring
crypto pki trustpoint TP-self-signed-2419240079
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2419240079
revocation-check none
rsakeypair TP-self-signed-2419240079
no ip domain lookup
ip domain name xxxx
ip name-server xxxx
ip name-server xxxx
username admin privilege 15 secret 5 $1$C6Dr$kCtbvShoEGvolf4xnZzrx.
username xxxx password 0 xxxx
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
group 2
lifetime 480
crypto isakmp client configuration group rtr-remote
key xxxx
dns x.x.x.x
domain xxxx
crypto ipsec security-association lifetime seconds 86400
crypto ipsec transform-set vpn1 esp-3des esp-sha-hmac
crypto ipsec client ezvpn ezvpnclient
connect auto
group ezvpnclient key xxxx
mode client
peer xxxx
xauth userid mode interactive
crypto dynamic-map dynmap 1
set transform-set vpn1
reverse-route
crypto map dynmap isakmp authorization list rtr-remote
crypto map dynmap client configuration address respond
crypto map static-map 1 ipsec-isakmp dynamic dynmap
archive
log config
hidekeys
interface ATM0
no ip address
ip virtual-reassembly
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
pvc 0/35
pppoe-client dial-pool-number 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
ip nat inside
ip tcp adjust-mss 1452
interface Dialer0
mtu 1492
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
no cdp enable
ppp pap sent-username xxxx password 0 xxxx
ip local pool vpn_addr_pool 192.168.11.10 192.168.11.20
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface Dialer0 overload
access-list 1 permit 192.0.0.0 0.255.255.255
dialer-list 1 protocol ip permit
no cdp run
control-plane
banner exec ^C
% Password expiration warning.
mhsrtr#
