Jaime Valencia Mon, 04/20/2009 - 10:40
  • Cisco Employee,
  • Hall of Fame,
    2011
check the optimize for low BW is not checked in your IPC, it causes G729 to be used
java
if this helps, please rate
wjwilson1 Mon, 04/20/2009 - 10:43
I read that may be the problem and already gave it a shot, but to no avail. any other suggestions ?
Jaime Valencia Mon, 04/20/2009 - 10:46
  • Cisco Employee,
  • Hall of Fame,
    2011
check your IPC DN has CSS that allows external calls
exactly what happens when you dial???
if it's "your call cannot be completed as dialed..." it CSS issue
check regions to make sure it's not codec issue
java
