04-20-2009 10:55 AM
Hi Friends,
I have an issue with the logs which get exceed the size limit such as CVDeviceselector.log,CSDiscovery.log,jrm.log,I have read the user guide CS3.1 Maintaining the log files but am not sure that the logrot file which am editing is correct as per the instruction.Am using LMS 3.0.1 and CS3.1.
What i understand from configuring logrot is what i have configured in attachment document. Please refer to attachments
Maintaining Log Files On Windows
To maintain log files on Windows:
Step 1 Make sure the new location has sufficient disk space.
Step 2 Go to the command line and make sure you have the correct permissions.
Step 3 Stop all processes by entering:
net stop crmdmgtd
Step 4 Perform log maintenance by running logrot.
See Configuring Logrot and Running Logrot for more information.
Step 5 Verify the procedure was successful by examining the contents of the log files in the following location:
NMSROOT\log\
Only log files that reach 90% of their size limits are backed up, and the original log file is emptied.
Step 6 Restart the system by entering:
net start crmdmgtd
Step 7 Select Server > Reports > Log File Status to view your log changes.
Using Logrot
The Logrot utility helps you manage the log files in a better fashion.
Logrot is a log rotation program that can:
⢠Rotate log when CiscoWorks is running.
⢠Optionally archive and compress rotated logs.
⢠Rotate log only when it has reached a particular size.
Logrot helps you add new files easily. Logrot should be installed on the same machine where you have
installed Common Services.
4-96
User Guide for CiscoWorks Common Services
OL-11776-01
Chapter 4 Configuring the Server
Administering Common Services
Configuring Logrot
To configure Logrot:
Step 1 Enter NMSROOT\bin\perl.exe NMSROOT\bin\logrot.pl -c (on Windows)
Step 2 Run /opt/CSCOpx/bin/logrot.pl -c (on Solaris)
The Logrot configuration menu appears. You have the following options:
⢠Edit variables.
⢠Edit log files.
⢠Quit and save changes.
⢠Quit without saving change.
Step 3 Select Edit variables to set your Backup Directory.
If you do not set a backup directory, each log will be rotated in its current directory.
Step 4 Select Edit log files to add log files you wish Logrot to rotate.
You can specify log files using fully-qualified or relative paths. If a relative path is specified, and the log
file does not exist in that path, the default log file path for your operating system will be added during
rotation (for example, /var/adm/CSCOpx/log on Solaris).
Step 5 Specify the number of archive revisions. If you do not want to keep any archives, enter 0 (the default)
for this option.
Step 6 Specify the maximum file size. The log will not be rotated until this size is reached. The unit is in
kilobytes (KB). The default is 1024 KB or 1 MB.
Step 7 Specify the file compression type to be used. It can be:
⢠Z-UNIX
⢠gz-GNU gzip (available by default on Windows only)
⢠bz2-bzip2 (available by default on Solaris8 and above only).
When deleting logfiles, you can choose to delete an individual file, a list of files, or all files matching a
certain pattern.
For example, 1-3 means delete files numbered 1 through 3. a list of comma-separated file numbers, for
example, 1,21, means delete files numbered 1 and 21. A pattern string *.log means delete all files that
match the pattern *.log.
You can also specify the special pattern, *, which means delete all logfiles in the configuration.
Running Logrot
To run Logrot enter:
⢠On Windows:
Enter NMSROOT\bin\perl NMSROOT\bin\logrot.pl
⢠On Solaris:
Solved! Go to Solution.
04-21-2009 09:25 AM
First, the log file name is jrm.log, not jrm. Second, restarting Daemon Manager does not run logrot. After you configure logrot, run:
D:\progra~1\cscopx\bin\perl D:\progra~1\cscopx\bin\logrot.pl -s
That will shutdown Daemon Manager, rotate the logs, then restart Daemon Manager.
04-20-2009 11:05 AM
Why are you modifying logrot.pl? You should NEVER touch any of the code in LMS. Restore the original logrot.pl.
From the command line, run:
NMSROOT\bin\perl NMSROOT\bin\logrot.pl -c
This will launch the logrot configuration menu. You can then add log files per the documentation in the online help.
To schedule logrot, use the Windows AT command. For example, to run logrot daily at 1:00 AM:
at 01:00 /every:M,T,W,Th,F,S,Su NMSROOT\bin\perl NMSROOT\bin\logrot.pl
Where NMSROOT is the path into which LMS is installed.
04-20-2009 11:22 AM
Hi clarke,
My CW LMS is installed in
D:program files\CSCOpx so my path in command prompt shld be as below:
D:\program files\CSCOpx\bin\perl d:\program files\bin\logrot.pl -c all this shld be in 1 row,still am confuse to understand NMSROOT\bin\perl NMSROOT\bin\logrot.pl -c command can u write for me as i have mentioned above my LMS location.
I remember once i tried by entering only
D:\program files\CSCOpx\bin\perl it stucks there for hours and hours no reponse only the cursor blinks.
Clark help me i was expecting ur call and i received ur reply.
04-20-2009 11:23 AM
The command is:
D:\progra~1\cscopx\bin\perl D:\progra~1\CSCOpx\bin\logrot.pl -c
04-20-2009 11:56 AM
Hi Clark,
Actually It is strange for me to excecute 2 times the same path
so i requested u to b more specific.Thanks the command is working i asked the helpdesk guy to execute the command it's fine,I will do the changes tomorrow and mail u the result,At present Am @ home.
Appreciate ur call.
Thanks once more.
04-21-2009 04:11 AM
Hi Clark,
step 3:edit variables
i specified d:\logsbackup
step 4:edit log files
i addedd the log file path shown in above attachment for jrm
d:\program files\cscopx\log\jrm
step 5:No of archives
i specified 50
step 6:maximum size
i set as default to 1024
step 7: compression
i specified windows default gz
and then q to go back
enter option:3 for quit and save changes
i did in proper way and then i stop the CW services by net stop crmdmgtd and then started again net start crmdmgtd but it does'nt work.
04-21-2009 09:25 AM
04-21-2009 11:58 AM
Hi Clark,
i got the Success clark,
I didnt find the above command in user guide CS 3.1.As i have posted in previous mail.The only difference between 2 commands is -c and -s. First i checked with jrm.log and 2nd with jrm but nothing happen.i was missing the above mail command.
C u in the next question soon am mailing.
Where i can write about u on cisco website can u give me any path.
Thanks clark u r genious.
