vlan routing.
sang-bong.lee
I set up router and switch to check vlan routing. below is the configuration I made. but ping is not successd.
could you please tell me what's wrong with my config?
[Router]
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.1
encapsulation dot1Q 2
ip address 10.43.2.1 255.255.255.0
interface FastEthernet0/0.2
encapsulation dot1Q 6
ip address 10.43.6.1 255.255.255.0
[Switch]
interface FastEthernet0/1
switchport access vlan 2
switchport mode access
interface FastEthernet0/2
switchport mode trunk
Switch#ping 10.43.2.1
Sending 5, 100-byte ICMP Echos to 10.43.2.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
bmcginn
Level 3
Level 3
Hi there,
Depending on the model of switch you're using, the encapsulation may be required for the trunk port.
ie:
interface fa0/2
Also, you should check to ensure that your VLAN 2 SVI is working and not shutdown. (switches default to vlan1).
Have you created the actual VLAN on the switch?
you should also check to ensure you have the default gateway on the switch.
good luck!
Brad
glen.grant
On the switch if you do a "show vlan" does vlan 2 and 6 show active ? If not you have not created the layer 2 vlan on the switch side . The rest of the config looks ok .
