1242 connectivity issue
anowell
Please see attached Visio to understand my topology. I am using a 1242 that is running c1240-k9w7-mx.124-10b.JDA.
Issue: When I try to use TCP 80 (HTTP) from the laptop I get "the page cannot be displayed" even though I can ping the server with 30 to 40ms ping times. If I used the wired computer I am able to HTTP to the server. Any idea what would allow the wired machine to connect but the wireless laptop to fail when using HTTP or any other application layer protocol? Please note that all the devices exist on a flat network and both the laptop and bridge are using the "A" radio on the 1242.
Thanks in advance!
Here is my config...
Wireless#sh run
Building configuration...
Current configuration : 2773 bytes
version 12.4
no service pad
service password-encryption
hostname Wireless
logging buffered warnings
logging console notifications
logging monitor notifications
enable secret 5 $1$7/oA$hurwSP15N3UgLWSzTvE6//
aaa new-model
aaa authentication login default local
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
clock timezone EST -5
clock summer-time EST recurring
no ip domain lookup
ip domain name MyHouse.com
dot11 ssid MySSID
authentication open
authentication key-management wpa
guest-mode
wpa-psk ascii 7 020E542200085E271D2f52
dot11 ssid aSSID
authentication open
guest-mode
wpa-psk ascii 7 011B335450055709721342
dot11 network-map
power inline negotiation prestandard source
username anthony privilege 15 password 7 XXXXXXXX
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers tkip
ssid MySSID
speed basic-1.0 basic-2.0 basic-5.5 basic-11.0 basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0
channel 2437
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
ssid aSSID
dfs band 3 block
speed basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0
channel 5200
station-role root
bridge-group 1
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address 10.10.10.5 255.255.255.0
no ip route-cache
ip default-gateway 10.10.10.1
ip http server
ip http authentication aaa
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
password 7 104A54327947165B0B
line vty 5 15
sntp logging
sntp server x.x.x.x
sntp broadcast client
end
gamccall
Level 4
Level 4
If you can ping the server, then layers 1-3 are working correctly. I'd check to see if there are any firewall/ port forwarding rules in your Linksys which might cause this.
Thanks for the response!
The Linksys bridge does not allow you to configure port forwarding and it does not have any firewall rules. Any other ideas?
Hmm. Put a sniffer on your "small switch" and observe both a ping conversation and an http attempt. It'd be helpful to know which packets are getting how far.
This isn't a DNS problem, is it? If you're pinging by numeric IP but browsing by hostname, that'd be one possibility...
I am using the IP to "http" to the box.
I will put a sniffer on the "small switch" side and capture the packets. Stay tuned! Thanks again.
