Question about the ICND1 exam.
Apr 20th, 2009
I can't find the answer anywhere. What is the passing score for this exam? I'll probably be taking it within the next two weeks. Thanks.
ccbootcamp Fri, 04/24/2009 - 07:32
IMHO, you shouldn't worry about the passing score, just focus on studying for the exam. If you get 1000 on the exam, you'll definitely pass. :)
But, since you asked the question, the passing score is 849 out of 1000.
ttyl
Brad
www.ccbootcamp.com
(please rate the post if this helps!)
tperrier Fri, 04/24/2009 - 22:48
Sure, but on the other hand, people scoring 1000/1000 rarely prepared using only Cisco approved material...
greg.washburn Mon, 04/27/2009 - 06:35
I just took the 640-822 about 3 weeks ago and it required an 804 to pass. The literature I read said it will be either 804 or 849.
It was stated to be 804 before I started the test as well as on my score report with my picture.
dave79111 Mon, 04/27/2009 - 06:40
Ok, thanks! I've been getting around 80% on the practice tests I've been taking.
