VLAN inquiry
Apr 20th, 2009
hello anyone who could assist me. I have attached my diagram and configurations as well. Just want to know if I did correct configurations for my devices? If yes, how come my colleagues who is handling the FW can not see R1(10.20.25.66) he can see VLAN2(10.20.25.65) and i can ping from the SW R1? Is there any wrong with my configurations? thanks
NickNac79 Mon, 04/20/2009 - 23:41
  • Bronze, 100 points or more
Hi Korbenda,
It looks like you don't have any routes on R1.
Try adding:
ip route 10.20.25.60 255.255.255.252 10.20.25.65
Unless this firewall is your link to the internet, in which case it should be
ip route 0.0.0.0 0.0.0.0 10.20.25.65
Hope that helps.
Please rate any posts you find useful.
korbenda11as Tue, 04/21/2009 - 17:37
hi,
I was able to ping R1 from the sw but not from the FW, and why is it ip route 10.20.25.60 255.255.255.252 10.20.25.65? R1 is part of the VLAN.
Is my configurations on SW, R1 and S1 are correct? if yes, what route are missing? thanks!
korbenda11as Wed, 04/22/2009 - 16:02
Hi Bhargav,
Are my configurations correct for the SW, R1 and S1? so you are saying that it just a routing issue? Do I need to configure routing to the SW?
NickNac79 Wed, 04/22/2009 - 23:54
Hi Korbenda,
As I said - you need routes on the router - else how does it know where to go to get to your firewall?
Add the following to R1:
The Firewall will also need a route into the network if it hasn't already - please copy the routing table here (Sanitise any public IP addresses) and we can have a look for you.
Nick
korbenda11as Mon, 04/27/2009 - 20:13
Hi, i have already add the route you mentioned and from FW it can already see the router. Now, the admin told me to add another route to the router so that I can access it from the internet. Do I need to add another route? is it 0.0.0.0 0.0.0.0 10.20.25.65, thanks!
Jon Marshall Mon, 04/20/2009 - 20:10
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Could you post diagram as a .jpg/.png
