ASA 5510 as VPN Hub
Apr 20th, 2009
I am a new of ASA. I setup several VPN tunnels between Data Centre, Headoffice, Site A and Site B. (Pls refer attachment)
Alls VPN tunnel are up. when I setup ASA in head-office as "VPN hub" so that Users in Site A and Site B are able to access the resources in Data Centre through ASA 5510
Everything is fine excecpt that the tunnel between Site A and Data Centre. Users are able to access the resources in Data Centre for 6-7 hrs only. Then, the VPN tunnel is dropped. When it happens, I checked that the VPN tunnel between Site A and head office is UP.
How to rebulid the the tunnel between Site A and Data Centre. I manually logoff the VPN tunnel and Data Centre with ADSM and let it up again.
If I don't do that, the tunnel between Site A and Data Centre will NOT resumed.
This is annoying for me. :(
Anyone has similar experience?
logintck Tue, 04/21/2009 - 04:18
Thank you for your reply.
What is reverse route injection?
During the Tunnel is down, I check real time log. I found that
Syslog ID: 106015
Deny TCP (no connection) from Site A IP/3510 to Data Cente IP/5060 flags RST on interface outside
