IP fragmenatation issue with DMVPN
Apr 21st, 2009
Dear Experts
We have Hub and spoke DMVPN over ADSL line .
the site -1 (Dubai) Services Provider has given ADSL line on Ethernet using GPON technology. even same cisco 2801 has terminated MPLS line over MPLS we have DMVPN .
Tunnel-1 is used for ADSL DMVPN
tunnel -2 is used for MPLS DMVPN .
Config for Tunnel -1 ---Branch Site
interface Tunnel1
description ** ADSL DMVPN **
ip address
no ip redirects
no ip proxy-arp
ip mtu 1492
ip nhrp authentication LanD3
ip nhrp map multicast dynamic
ip nhrp map multicast x.x.x.x
ip nhrp map x.x.x.x
ip nhrp map x.x.x.x
ip nhrp network-id 12
ip nhrp holdtime 600
ip nhrp nhs
ip nhrp nhs
ip tcp adjust-mss 1400
ip ospf network broadcast
ip ospf cost 20
ip ospf priority 0
keepalive 10 3
tunnel source Dialer0
tunnel mode gre multipoint
tunnel key 1
tunnel protection ipsec profile DMVPN
Same MTU and IP tcp Adjust-mss 1400 has used on Hub side cisco 3845 router.
Following Issue we are facing.
1. Client -Server based application is not working through Tunnel-1 ( I am able to reach servers from client)
2. RDP is not working .
I have try to reduce mss 1300,1340,1360 on both site tunnel but no use .
Even if ping -l 1400 to my server ip i am not able to ping.
If i am ping -l 1384 to server ip I am able to ping
IOS ver 12.4(20)T2
Apart from
I have another site ( Abu Dhbai )where ISP given ADSL line WITH same technology on ehternet where my ADSL DMVPN working fine with all Client -server based apps as well as RDP .
same configuration ON TUNNEL-1 config.
This site I am using 1841 with IOS 12.4.(15)T8 .
Pls help me to solve this issue wht could be the reason ??????
Is it issue with ISP that IP fragmentation is not supporting in DUBAI line.
Anonymous (not verified) Mon, 04/27/2009 - 13:06
If it is IP fragmentation issue then one of the soultion would be configuring TCP MSS. The TCP Maximum Segment Size (MSS) defines the maximum amount of data that a host is willing to accept in a single TCP/IP datagram. This TCP/IP datagram may be fragmented at the IP layer. The MSS value is sent as a TCP header option only in TCP SYN segments. Each side of a TCP connection reports its MSS value to the other side. Contrary to popular belief, the MSS value is not negotiated between hosts. The sending host is required to limit the size of data in a single TCP segment to a value less than or equal to the MSS reported by the receiving host.
