CRC errors on switch port
Apr 21st, 2009
reliability of gig port of layer 3 switch is 249 and there are CRC errors on the link . tried changing the ports but no solution. what can be the problem and kindly suggest some solution.
sh int is attached herewith.......
GigabitEthernet1/0/1 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 0013.1a91.9401 (bia 0013.1a91.9401)
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 249/255, txload 1/255, rxload 1/255
Keepalive not set
Full-duplex, 100Mb/s, media type is 10/100/1000BaseTX SFP
input flow-control is off, output flow-control is unsupported
Last input 00:00:00, output 00:00:13, output hang never
Last clearing of "show interface" counters 01:14:34
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 124000 bits/sec, 109 packets/sec
5 minute output rate 58000 bits/sec, 5 packets/sec
411048 packets input, 82702630 bytes, 0 no buffer
Received 354522 broadcasts (0 multicast)
12303 input errors, 5101 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 89607 multicast, 0 pause input
57360 packets output, 16181784 bytes, 0 underruns
thotsaphon Tue, 04/21/2009 - 00:54
  • Gold, 750 points or more
yogesh,
Which device is this port connecting to?
It's running at 100Mbps/Full-Duplex. Properly be a fiber port.
You may check the cable and duplex on both sides.
HTH,
Toshi
patrickvanham Tue, 04/21/2009 - 01:58
The most common cause for CRC errors on a switch port is a duplex mismatch. The other end is probably set to auto or perhaps even half. If both ends are set to full the CRC errors will usually stop. Otherwise there may be a cabling or hardware problem
csc010854800 Tue, 04/21/2009 - 02:28
i have found a duplex mismatch on trunk port , but i am not able to convert it to full duplex. port goes down as i try to do it.
Also , i am not getting errors on this port . some other port is generating CRC errors.
any solution ???
