04-21-2009 01:16 AM - edited 07-03-2021 05:27 PM
Is there any way to run Location Appliance (2710) software on a virtual machine with a trial license for testing and/or educational purposes?
04-29-2009 05:15 AM
Not unless the location sw is available under special file access from CCO.
Otherwise you will have to get the location appliance (cisco colored ibm server running redhat ES 4+location server)
I haven't toyed with it that much, but it would not be too hard to build a redhat vm and try to pull over the location sw from a location appliance; whether it works or not is another question! But that would require that you purchase the location appliance.
04-29-2009 07:47 AM
That's something I'd like to know too. If this appliance is like CUCM ones, there would be no need to pull the software from the appliance, just use the installation/recovery DVD!
05-06-2009 09:26 PM
You cannot install the location appliance software on a vmware server. There is a hardware check which will prevent operation in case you you try to start it up on any server other than the one acquired though Cisco.
Pushkar
05-06-2009 10:47 PM
yup yup ...no can do .. i looked into this over a year ago ..
