ntp references on cucm 6.X subsribers
Apr 21st, 2009
Hi, Managed to setup ntp references with my cluster butt then had to change the names of the servers at the last minute. Anyhow, the subscribers are still referencing the old publisher name as the ntp reference and hence cannot get the correct time. Any ideas on how to delete this on the subscribers?
Thanks in advance
Overall Rating: 5 (1 ratings)
gogasca Tue, 04/21/2009 - 03:13
You can try to restart ntp service by CLI
utils ntp restart
but if entries are already in ntp.conf using old name, we may need root access to modify them.
You are hitting: CSCsy71974
You need to contact us to get access and modify ntp.conf
