QOS query
mahesh-gohil
policy-map in_CE_ABC
class class-default
police cir 3072000 bc 576000 be 1152000 conform-action set-mpls-exp-imposition-transmit 5 exceed-action transmit violate-action transmit
In above command how much bw customer able to enjoy and what happens if i do exceed-action drop instead of transmit
Mahesh
Laurent Aubert
Hi Mahesh,
With this configuration, your customer will be able to use 100% of the available bandwidth.
If you replace exceed-action transmit violate-action transmit by exceed-action drop, your customer will have 3Mbps available assuming your cir is in bps
Laurent.
