NAT Problems (877W)
Apr 21st, 2009
I have 2 routers (877W and 3825) connected back to back, I am trying to configure NAT but when I configure my access-list to match the network that must be translated I can't hop from one router to the other. But the traffic sent is received on the other side.
attached is both routers configs. Another problem here is on router 877 when I configure IP NAT INSIDE on int vlan2 traffic drops from 877.
All pings are successful on both directions.
Router 877
interface Loopback0
ip address 1.1.1.1 255.255.255.255
ip virtual-reassembly
interface Loopback1
ip address 10.1.1.1 255.255.255.0
interface Vlan1
description Connection to Router 3825
ip address 192.1.1.1 255.255.255.252
ip nat outside
interface Vlan2
description Home LAN
ip address 192.4.1.1 255.255.255.0
ip route 0.0.0.0 0.0.0.0 Vlan1
ip access-list extended Mpho
permit ip any any
deny ip host 10.0.0.1 any
ip nat inside source list Mpho interface Vlan1 overload
Router 3825
interface Loopback0
ip address 2.2.2.2 255.255.255.255
interface Loopback1
ip address 20.0.0.1 255.255.255.0
interface GigabitEthernet0/0
ip address 192.2.1.1 255.255.255.0
duplex full
speed 100
interface GigabitEthernet0/1
ip address 192.1.1.2 255.255.255.252
ip nat outside
duplex full
speed 100
ip nat inside source list Mpho interface GigabitEthernet0/1 overload
permit ip 192.2.1.0 0.0.0.255 any
permit ip host 2.2.2.2 any
Giuseppe Larosa Tue, 04/21/2009 - 04:52
Hello Lawrence,
it should be better defining the ACL in the more specific way.
Also specific deny statement needs to be configured first or they will never match
permit ip any any
another suggestion is to use a standard ACL at first for NAT
like
access-list 11 permit 192.4.1.0 0.0.0.255
I would use a route-map to use an extended ACL like
access-list 114 deny ip any host 10.0.0.1
acess-list 114 permit ip 192.4.1.0 0.0.0.255 any
route-map selected-NAT permit 10
match ip address 114
and the line becomes
ip nat inside source route-map selected-NAT interface Vlan1 overload
And also
int vlan 2
ip nat inside
Hope to help
Giuseppe
thotsaphon Tue, 04/21/2009 - 04:55
Lawrence,
Actually when doing NAT you still need a route to tell it how to route packets out of which the interface. Because the routing process is performed first(inside to outside).
In the Ethernet segment. I would reference the next-hop to reach the other networks. You will get problems when disabling proxy-arp functions at the far end.
I wouldn't use "permit ip any any" in NAT statement. Because you will get problems when connecting to the router itself.
Router 877
ip route 0.0.0.0 0.0.0.0 192.1.1.2
interface Vlan2
ip nat inside
Router 3825
ip nat inside
When you initiate traffic from here. You need a route.
ip route 0.0.0.0 0.0.0.0 192.1.1.1
HTH,
Toshi
