logging
Apr 21st, 2009
can someone help me how to setup logging to external server?
I have catalyst 3750G-PoE and windows based OS. I want to send all logging messages that are possible from 3750 to file on host. I dont know if i need same program and how to setup this program that i will recieve logs from switch and how to setup switch that all messages produced by switch will be visible in same file on host.
I was trying for kiwi syslog server but no messages were recieved...(maybe bad setup?)
Thanks.
greg.washburn Tue, 04/21/2009 - 05:30
Once you have kiwi installed on your syslog server. Do the following.
Make sure no firewalls are blocking the port you choose to send logs on.
On the switch/router:
config t
logging "server ip"
ctrl + z
copy run start
