ACE - Defining multiple web sites on same VIP
Apr 21st, 2009
Currently the following config works with single website running on SERVERFARM1. There is a new requirement to host multiple websites on the same SERVERFARM1. Since the VIP would be the same, what additional statements do I need to enter into the class-map to match the host header values other than the VIP.
class-map match-all VIP-SITE1
2 match virtual-address 192.168.160.1 tcp eq www
policy-map type loadbalance first-match LB-SITE1
class class-default
sticky-serverfarm SERVERFARM1
policy-map multi-match LB-VIP-FROM-CLIENT
class VIP-SITE1
loadbalance vip inservice
loadbalance policy LB-SITE1
loadbalance vip icmp-reply
dario.didio Tue, 04/21/2009 - 05:43
  • Silver, 250 points or more
If you want to match on the host-header, following config should work:
serverfarm host SERVERFARM1
class-map type http loadbalance match-any SITE1
match http header Host header-value http://www.site1.com
class-map type http loadbalance match-any SITE2
match http header Host header-value http://www.site2.com
class-map type http loadbalance match-any SITE3
match http header Host header-value http://www.site3.com
policy-map type loadbalance http first-match SITE_L7_POLICY
class SITE1
class SITE2
class SITE3
policy-map multi-match VIPs
class VIP-SITE
loadbalance policy SITE_L7_POLICY
loadbalance vip icmp-reply active
HTH,
Dario
