How can I change Wifi IP on WRVS4400Nv2?
Answered Question
Apr 21st, 2009
Hi all,
I use a WRVS4400Nv2 router with firmware V1.00.09-ETSI.
I've noticied in the status pages that the router has 2 IP address. The first is associated to the LAN interface and the second to the WLAN interface. I can easily change the IP on LAN interface in the Setup/LAN page but I cab't found a way to change the IP address associated to the WLAN interface ?
If someone has some suggestion, you're welcome.
Correct Answer by ntarazi about 7 years 11 months ago
the WLAN IP comes from the router DHCP server, to change it need to change the router 's LAN IP address
Overall Rating: 5 (1 ratings)
ntarazi Wed, 04/22/2009 - 15:30
  • Cisco Employee,
Need to change your Internet Connection Type in the setup menu to Static IP instead of DHCP
jonathand131 Thu, 04/23/2009 - 00:10
I want to change WLAN IP, not WAN IP.
The WLAN IP is displayed in Status/Wireless LAN page but I can't find where to change it.
Correct Answer
ntarazi Thu, 04/23/2009 - 08:16
  • Cisco Employee,
jonathand131 Thu, 04/23/2009 - 08:34
Thanks for the tips, I've found where it is.
On the Setup/LAN page, the LAN IP can be changed with the "Local IP Address" settings. Below, there is on option called "IP Reserved for Internal Usage". This is in fact the IP used for WLAN interface. I've changed it, saved settings and checked on Status/Wireless LAN page and this is the right settings.
Related Content
