VSS Dual active detection
huangedmc Thu, 04/23/2009 - 03:11
No.
The dual active detection you described is supported by enhanced PAgP, which is only supported by newer versions of IOS on certain CISCO switches.
It doesn't work w/ Nortel switches.
Even regular PAgP doesn't work w/ non-Cisco switches.(most of them don't support it)
This should be in the LAN switching section instead of application anyway.
huangedmc Thu, 04/23/2009 - 05:30
You mean one VSS member switch in one datacenter, and the other member switch in the second datacenter?
I wouldn't recommend doing VSS across WAN/MAN.
Remember the dual active detection using enhanced PAgP is done through downstream switches that have MEC to the VSS chassis'.
This means one link goes to the local VSS member switch, and the other link would go through the WAN, onto the other VSS member switch.
Also, the main benefit of doing VSS is to cut down your spanning-tree domain.
To really take advantage of that you'd have uplinks from downstream switches to both VSS member switches across WAN/MAN, which just isn't an efficient way to mesh your switches.
