MARS login
Apr 21st, 2009
I am constantly required to login to MARS when I change pages. For instance, if I am configuring alerts and close the pop-up windows to return to the Admin tab and add a user, it logs me out. Any idea why I should have to login over and over? Thanks in advance!
MARS 6.0.2
Overall Rating: 3 (2 ratings)
didyap Fri, 05/01/2009 - 11:15
Did you ever get an answer on this? I'm seeing a similar problem.
jcoudrain Fri, 05/01/2009 - 11:31
I did not get an answer, but I was using IE8, and even with compatibilty mode, it behaved the same way. I switched workstations to use IE7 and it works great. If you have that possibility, that is what I recommend.
