donnaavila Tue, 04/21/2009 - 09:03
No question is dumb. Go into User Management > End User > put in the extension and then hit find. Then at the top right side, scroll down to related links and click on dependency records. Click go and then you will click on phone and that should tell you the device the user is logged into.
I hope this helps.
Donna
Jaime Valencia Tue, 04/21/2009 - 09:04
device -> phone -> related links -> Actively Logged In Device Report
java
if this helps, please rate
