VPN Connection cause reboot
Apr 21st, 2009
I working with a remote site that uses the Cisco VPN client to access a customers database. After the client disconnects from the network all active connections are lost (email, internet, until the machine is rebooted. The version of the VPN client I am using is 5.0.05.0290, on xp. I'm wondering if this is a bug or known issue with this client.
drolemc Mon, 04/27/2009 - 12:51
  • Silver, 250 points or more
If you are using Sata drive then there is chance to occur this problem. Install new patches on your xp then try.
