Help with station-role command
Answered Question
Apr 21st, 2009
What exactly is the dfference between these commands:
station-role non-root
station-role non-root bridge
station-role non-root bridge wireless-clients
station-role root
station-role root access-point
station-role root ap-only
station-role root bridge
station-role root bridge wireless-clients
I am trying to bridge the wireless unit to two two Vlans on the 861W. I need two SSIDs, one for each Vlan.
Correct Answer by gamccall about 8 years 3 months ago
OK. So in that case, you just want the ISR to function as an AP. "Station-role root access-point" should accomplish that.
Here's the config guide for vlans on an ISR:
http://www.cisco.com/en/US/docs/routers/access/1800/wireless/configuration/guide/s37vlan.html
Overall Rating: 4 (1 ratings)
gamccall Tue, 04/21/2009 - 10:08
  • Silver, 250 points or more
In Access Points, "station-role non-root" and "station-role non-root bridge" are the same. On the ISRs, the two commands are different: "station-role non-root" is considered the universal client mode and "station-role non-root bridge" is considered the non-root bridge mode.
To trunk multiple vlans, you will want bridging, not universal client. So, you'll have one ISR as "station-role root bridge" and the other as "station-role non-root bridge". Add the "wireless clients" keyword to either or both if you want to allow laptops to associate, or not if want to restrict wireless traffic to just the bridge link.
You only need one SSID, for your native vlan. Other vlans will be trunked as subinterfaces but will be carried over the same SSID. So, a sample config:
dot11 ssid MySSID
vlan 1
authentication open
authentication key-management wpa version 2
wpa-psk ascii MySuperSecretKey
int d0
ssid MySSID
encryption vlan 1 mode ciphers aes
int d0.1
encap dot1q 1 native
bridge-group 1
int f0.1
bridge-group 1
int d0.10
encap dot1q 10
bridge-group 10
int f0.10
encap dot1 10
bridge-group 10
thomasmcleod Tue, 04/21/2009 - 14:40
Thanks for the reply, but I think you misunderstood my topology.
I have two wired VLans on the 861W. I want to bridge those VLans to the radio, one each on it's own SSID, so that clients can connect to those VLans through the radio.
What is the difference between station-role root and station-role non-root? Is there a document that explains this?
gamccall Tue, 04/21/2009 - 19:04
Are you trying to do any bridging at all between the two 861W's, or are both ISRs just servicing clients?
thomasmcleod Thu, 04/23/2009 - 07:45
I have only one 861W. It's WAN side is connected via wire to a DSL modem. The LAN side has two VLans on two different subnets.
By bridging, I was talking about bridging between those subnets through the integrated access point. I want two different SSIDs on the radio, one each for the two subnets.
Thanks.
thomasmcleod Fri, 04/24/2009 - 21:34
Thanks gamccall. That helped. I think I have a basic wireless config, but I don't think I'm getting DHCP through the wireless. I also need NAT to function through the wireless.
Configs (router and ap) attached.
taylangulmez Tue, 11/06/2012 - 03:20
I have AP 1131G Aironet and I purchased to use for Polycom device but after reading all manual still could not manage to
configure the interfaces .
I would appreciate if someone help i can even give access to my computer to use serial port or web interface.
It is basically same network with PBX device and one polycom 8440 which Cisco device certified polycom model.
current wireless device connection dropping
Thank you
Taylan
kcnajaf@25070 Tue, 11/06/2012 - 03:56
  • Gold, 750 points or more
Hi Taylan,
You should have opened this as a new post as your using completly a different hardware. Could you please open a new post for your issue along with the current running configuration of the AP?
Najaf
kcnajaf@25070 Tue, 11/06/2012 - 03:54
Hi Thomas,
I have not worked on 861W before but still your configuration looks fine. I hope what you are saying here is client are connecting to wireless but not able to recieve DHCP ip address. This may be due to the fact that your two vlans are not trunked to the switch.
Can you please apply below config and give a try?
config terminal
vlan 2
vlan 3
interface Wlan-GigabitEthernet0
switchport trunk native vlan 1
switchport mode trunk
Also please provide the output of
show interface wlan-gig0 trunk
Najaf
