04-21-2009 09:21 AM - edited 07-03-2021 05:28 PM
I have a controler 4402 with somes LAP1242, i want to know if the controler is shutdown, AP1242 lose his configuration or stay up and continue to operate ?
Thanks a lot
Solved! Go to Solution.
04-21-2009 03:58 PM
H-REAP Modes of Operation Configuration Example
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00807cc3b8.shtml
H-Reap Design and Deployment Guide
http://www.cisco.com/en/US/products/ps6087/products_tech_note09186a0080736123.shtml
04-21-2009 01:53 PM
Hi Alexandrine,
Here's the gist of it all. By default, if you configure your WLC normally, the AP's run in a mode called "AP Mode". When this happens, if your one-and-only goes down for maintenance (like firmware upgrades), the AP's will stop and search for a controller until one is found.
However, if you operate in H-REAP mode, when your one-and-only WLC goes down AND your don't reboot your AP's, the AP's will operate normally.
Does this answer your question?
04-21-2009 11:07 PM
Thanks a lot for your quickly response
04-21-2009 03:58 PM
04-22-2009 02:45 PM
Thanks for the ratings. :)
