WPA/AES and WPA2/AES
Answered Question
Apr 21st, 2009
Is there any difference between WPA/AES and WPA2/AES. I realize that WPA was pre-standard but I'm wondering if there are any "technical" differences.
Any help is greatly appreciated.
Correct Answer by gamccall about 7 years 9 months ago
Security is the same. There are differences under the hood with regard to roaming and caching, header labels, and a few other things. WPA/AES is not tested during the WiFi Alliance certification process so there's potential for compatibility issues.
If your clients can't support WPA2 then they probably can't support WPA/AES either, so my thinking is go with the certified combinations and do WPA2/AES and WPA/TKIP. (There's no reason in the world to enable WPA2/TKIP since all WPA2 clients must support AES.)
Overall Rating: 4 (2 ratings)
Correct Answer
gamccall Tue, 04/21/2009 - 11:07
Trending Topics - Security & Network
