GRE Tunnel Not Working
Answered Question
Apr 21st, 2009
Hi, Im trying to set up a GRE tunnel in a lab and Im getting a recursive routing issue.
What I would like to accomplish is to have 2 routers establish a GRE tunnel between them, create an eigrp neighbor relationship, and begin exchanging routes.
As it is, each router has no neighbors because each is connected to a switch with nothing but statics to facilitate the creation of the tunnel. So, the expectation is that the tunnel will come up, negotiate an eigrp neighborship and exchange routes...
Not working...:-(
Here are the configs. Can someone tell me where exactly Im going wrong?
L3 SWITCH
interface Loopback1
ip address 1.1.1.3 255.255.255.255
interface Loopback2
ip address 2.2.2.3 255.255.255.255
interface Loopback3
ip address 3.3.3.3 255.255.255.255
interface Loopback4
ip address 4.4.4.3 255.255.255.255
interface Tunnel1
description GRE TUNNEL TO ROUTER 1
ip address 50.50.50.1 255.255.255.0
tunnel source 20.20.20.1
tunnel destination 1.1.1.1
interface FastEthernet0/22
description ROUTED CROSSLINK TO SWITCH 1
no switchport
ip address 20.20.20.1 255.255.255.252
router eigrp 10
network 1.1.1.3 0.0.0.0
network 2.2.2.3 0.0.0.0
network 3.3.3.3 0.0.0.0
network 4.4.4.3 0.0.0.0
network 20.20.20.1 0.0.0.0
network 50.50.50.1 0.0.0.0
network 172.16.14.3 0.0.0.0
network 172.16.15.3 0.0.0.0
no auto-summary
eigrp log-neighbor-changes
ip classless
ip route 0.0.0.0 0.0.0.0 20.20.20.2
ip route 1.1.1.1 255.255.255.255 20.20.20.2
ROUTER
interface Loopback0
ip address 1.1.1.1 255.255.255.255
ip virtual-reassembly
interface Loopback1
ip address 5.5.5.5 255.255.255.255
interface Loopback2
ip address 6.6.6.6 255.255.255.255
interface Loopback3
ip address 7.7.7.7 255.255.255.255
interface Loopback4
ip address 8.8.8.8 255.255.255.255
interface Tunnel1
ip address 50.50.50.2 255.255.255.0
tunnel source 1.1.1.1
tunnel destination 20.20.20.1
interface FastEthernet0/0
ip address 10.0.0.1 255.255.255.252
ip accounting output-packets
ip nat outside
speed 100
full-duplex
router eigrp 10
network 1.0.0.0
network 5.0.0.0
network 6.0.0.0
network 7.0.0.0
network 8.0.0.0
network 10.0.0.1 0.0.0.0
network 50.50.50.2 0.0.0.0
no auto-summary
no ip http server
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.0.0.2
02:27:18: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel1, changed state to up
02:27:18: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 10: Neighbor 50.50.50.1 (Tunnel1) is up: new adjacency
02:27:27: %TUN-5-RECURDOWN: Tunnel1 temporarily disabled due to recursive routing
02:27:28: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel1, changed state to down
02:27:28: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 10: Neighbor 50.50.50.1 (Tunnel1) is down: interface down
02:28:28: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel1, changed state to up
02:28:28: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 10: Neighbor 50.50.50.1 (Tunnel1) is up: new adjacency
02:28:37: %TUN-5-RECURDOWN: Tunnel1 temporarily disabled due to recursive routing
Correct Answer by Edison Ortiz about 8 years 1 month ago
That's correct.
20.20.20.0/30 shouldn't be in the EIGRP routing process since it's used as the tunnel source for the L3 switch.
With that said, you shouldn't use a loopback that is advertised by EIGRP as a source or destination in the tunnel - I recommend using the egress interfaces on both devices and don't advertise these interfaces in EIGRP.
__
Edison.
Overall Rating: 5 (3 ratings)
Edison Ortiz Tue, 04/21/2009 - 10:58
  • Hall of Fame,
    Founding Member
A router can't learn the tunnel destination IP address via the tunnel hence the recursive problem.
You need to modify your config as follow:
L3 Switch
interface Tunnel1
tunnel destination 10.0.0.1
router eigrp 10
no network 20.20.20.1 0.0.0.0
ROUTER
interface Tunnel1
tunnel source 10.0.0.1
router eigrp 10
no network 10.0.0.1 0.0.0.0
HTH,
__
Edison.
ex-engineer Tue, 04/21/2009 - 11:13
Hi, Edison:
Hope you;re having a good day.
Thank you for that quick response.
before you responded, however, I made some changes after I refreshed my memory a little better on what exactly is meant by recursive tunnel routing.
What I did on the L3 switch was to stop advertising/running eigrp on the 20.20.20.0 network.
On the router, I created a static route to the tunnel destination, but I probably didnt have to do that because I already had a default route.
I think the one command that really fixed it was on the L3 switch, in which I stopped advertising the 20.20.20.0 network because that included the tunnel destination.
Your thoughts?
Correct Answer
Edison Ortiz Tue, 04/21/2009 - 11:30
  • Hall of Fame,
    Founding Member
That's correct.
__
Edison.
ex-engineer Wed, 04/22/2009 - 08:58
Edison:
Without keepalives configured on the tunnel interfaces, and without using a dynamic routing protocol (just statics), what keeps a tunnel interface "up"?
I did have eigrp configured between tunnel endpoints yesterday, but I removed it and am just using static routes to destination networks that point to the tunnel:
ip route 5.5.5.5 255.255.255.255 tunnel1
I also disabled keepalives.
Yet the tunnel stays up forever.
Why?
Edison Ortiz Wed, 04/22/2009 - 10:10
  • Hall of Fame,
    Founding Member
A GRE tunnel will come up as long as the source interface of the tunnel is up and the destination IP in the routing table.
The keepalive feature enables the ability to bring down the tunnel if the far end is unreachable. The destination IP can be in the routing table (static, for instance) and at the same time be unreachable.
For more information, please take a moment to read this document:
http://www.cisco.com/en/US/tech/tk827/tk369/technologies_tech_note09186a008040a17c.shtml
HTH,
__
Edison.
ex-engineer Wed, 04/22/2009 - 10:33
Hi, Edison:
I appreciate the answer.
Im pretty familiar with the keepalive system and the documentation was easy to find. I actually read that document already.
"A GRE tunnel will come up as long as the source interface of the tunnel is up and the destination IP in the routing table."
This is the part I didnt know about. And I cant seem to find a document that discusses this point.
Do you know of one?
Edison Ortiz Wed, 04/22/2009 - 10:40
  • Hall of Fame,
    Founding Member
No, that part I tested in the Lab.
__
Edison.
pszczola1 Wed, 04/22/2009 - 13:37
If I can add something to this discussion. I had recently the same issue. I couldn't remove my tunnel source address from eigrp, since it was a ingress interface of my router facing LAN. I was able to solve the recursive routing problem, by adding the static route to the tunnel destination on each of the routers.
This document is quite good.
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094690.shtml
