VPN Client 5.0.04.0300 Installation Issue
Apr 21st, 2009
When I try installing the VPN Client ver 5.0.04.03000 I get an error message saying "Error 27854: The Network Configuration LOck is held by another application. Close all applications and run Setup again. ..."
c
I have tried shutting down all processes in Task Manager and any services to no avail. I have tried logging in as a local user ... same error. And have tried rebooting in Safe Mode but get error saying the system admin won't allow me to install.
Lastly, I scoured to web and found nothing. Mine is the only laptop (Dell D630) which won't allow. All other D630's will allow the install.
Please help.
Overall Rating: 5 (1 ratings)
DialerString_2 Thu, 04/23/2009 - 10:08
I would try disabling your network interfaces, including the WIFI. I hate to type the following but, use MSCONIG.
samcapaldi317 Thu, 04/23/2009 - 10:36
Thanks. I disabled every network adapter and interface in MSCONFIG and under Device Manager but still received the same error message.
vvelagan007 Fri, 05/01/2009 - 20:13
I'm facing the same problem on my laptop (OS: Windows Vista Home Premium 32-bit, SP 1). I've tried many options as samcapaldi317 tried but all my efforts are in vain. I would encourage Cisco to find a solution and if there are any suggestions, I'd really appreciate if you post them.
Thanks.
