Error during configuring AIP SSM-10 with ASA 5520
Apr 21st, 2009
Dear Concerns,
Error occurring while trying to configuring new AIP SSM-10 module with new ASA 5520. Following error shown during start of session
"Authentication token manipulation error
Remote card closed command session...press any key to continue....."
i have also tried to ASDM IPS option but there is also showing error that
"destination unreachable of ....."
Kindly advice..
Thanks and Regards
roshan.maskey Tue, 04/21/2009 - 16:19
IF you are trying to access AIP-SSM for the first time from ASA, then try using command line.
ASA5520 and AIP-SSM are two different unit and each has its own credentials. The default username password for AIP-SSM is cisco/cisco. AIP-SSM will ask you to change password.
H2H
Roshan
