Maulik Shah Tue, 04/21/2009 - 18:17
  • Silver, 250 points or more
Do a show controller t1 - check for items based on flow chart at link below:
http://www.cisco.com/en/US/tech/tk713/tk628/technologies_tech_note09186a...
If there is a remote alarm - it implies the far end is at fault i.e. your provider. Another test to ensure its not a HW issue is to create a hardware loopback plug and check if the controller comes up if loopback cable is in - if it comes up then you know its not the UC520
