POTS Dial Peer Question
Answered Question
I have H.323 gateway and CUCM6.1 I have voice ports on gateway connected to POTS Lines for outbound calling. I have thee pots dial peers for outbound PSTN calls.
911 for emergency
9911 for emergency
9[2-9][2-9]..... for local calling
when I dial 9911 there is a long paude almost 5 seconds before the call connects. Is there a way to make 9911 calls match this dial peer instead of timming out and then matching it?
The actual dial peers are below
Thank you
dial-peer voice 999024 pots
destination-pattern 911
port 0/1/0
forward-digits 3
dial-peer voice 999025 pots
destination-pattern 9911
port 0/1/0
forward-digits 3
dial-peer voice 1 pots
destination-pattern 9[2-9]......
port 0/1/0
forward-digits 7
Correct Answer by Rob Huffman about 8 years 4 days ago
Hey Guys,
Well, you learn something new every day! +5 points for each of you. Nick, Gonz and Sushil, thanks for weighing in on this and for your continued participation here.
Great work!
Now I'm curious to see what works best for Eric.
Cheers!
Rob
Overall Rating: 4.8 (6 ratings)
Rob Huffman Tue, 04/21/2009 - 17:27
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Eric,
The 5 second pause is surely the inter-digit timeout. In your example you have;
but in your actual dial-peer you have;
I would try setting the actual dial-peer like the example.
destination-pattern 9[2-9][2-9]......
Hope this helps!
Rob
Sushil Kumar Katre Tue, 04/21/2009 - 19:36
  • Gold, 750 points or more
Hi Eric,
I agree with what Rob has stated.
Since your actual dial peer is 9[2-9]...... when you dial 9911, there are two dial peers whcih are matching. Because of this dial peer you are observing that pause which I also feel is inter-digit timeout
-> Sushil
Nicholas Matthews Tue, 04/21/2009 - 19:53
  • Red, 2250 points or more
Actually, the way that dial peers are matched on gateways don't work quite this way. This is the operation on CCM/CUCM, but not gateways.
Gateways by default will do 'urgent priority' when you dial. If you have a dial peer that matches a pattern it will be routed immediately.
Example:
destination-pattern ...
dial-peer voice 2 pots
destination-pattern ....
If you were to dial digit by digit on a phone connected to this gateway, you will hit dial peer 1 every single time.
I would need to test this, but when you receive the digits as a block in a H323 setup, you may be able to hit the second dial peer here. But unless you have overlap receiving on, you're not going to use the interdigit timeout.
In order to troubleshoot this I would turn on these three debugs:
debug voip ccapi inout (general call processing)
debug h225 asn1 (when the setup comes in)
debug vpm signal (check signaling on the voice-port)
You probably want this command:
service timestamps debug datetime msec local
My guess is that either 1) Your delay is in the time sending the H323 setup to the gateway via a route pattern in CUCM 2) Slow connection via the FXO port
Best way is to enable the debugs and look a the time stamps. If you see the setup come in 5 seconds before the vpm debugs, then it could be interdigit / overlap receiving.
Otherwise you're looking at something else.
-nick
Sushil Kumar Katre Tue, 04/21/2009 - 20:13
Hi Nick,
But if you see the dial peer -
9[2-9]...... is dial peer number 1
while
9911 is dial peer number 999025
So whenever you dial 9911, it will always hit dialpeer 1, since preference for both the dial peers are same "0"
Dial peer 1 is expecitng more number, hence interdigit timeout.
-> Sushil
gogasca Wed, 04/22/2009 - 02:14
  • Green, 3000 points or more
Use $ as termination symbol
gogasca Wed, 04/22/2009 - 02:15
He can change it to be 9911$
Nicholas Matthews Wed, 04/22/2009 - 05:05
I haven't seen a scenario where adding the $ helps anything, but I've never tried.
If it was an interdigit timeout issue you can enter # after the number because it's the default terminator.
-nick
Nicholas Matthews Wed, 04/22/2009 - 05:03
Hi Sushil,
Preference only matters for equal-length destination patterns.
You can try it in the lab if you like.
With your theory, it would always hit the first dial peer. By default, if multiple dial peers match, it would round robin them. But again, this is only for same-length destination patterns or if both dial peers have a T in the string.
-nick
Sushil Kumar Katre Wed, 04/22/2009 - 06:58
Nick, I goofed it up. You are correct.
Thanks Nick
-> Sushil
Correct Answer
Rob Huffman Wed, 04/22/2009 - 05:13
  • Hall of Fame,
    Founding Member
Hey Guys,
Great work!
Cheers!
Rob
