04-21-2009 05:42 PM - edited 03-15-2019 05:35 PM
There is a unity server installed and working with VM messaging, Exchange and active directory are installed in the same unity server. Currently there is no failover; the customer wants to have redundancy now
Is it necessary to reinstall the current unity server that is going to be the primary server?
04-22-2009 12:12 AM
not really but exchange needs to be offbox, u can install the exchange in different machine then move the mailboxes and re-run mscw, then install secondary server.
04-22-2009 05:37 AM
Hi, thanks for your response
where can I check that option?
do you have a link where I can follow that procedure?
thanks again
