csim start
Apr 21st, 2009
Can we use csim start <Mobile nukmber> command to check the voice call connection for PRI lines.Because for few service provider the calls are not established.when checked with debug we have found an error "**ERROR**: isdnAsn1Component: ERROR" & "**ERROR**: process_facility_supp_services: Decode of facility IE operation failed"
Pls help..
gogasca Tue, 04/21/2009 - 23:14
yes u can try, but whats the call flow...?
Can you use an IP communicator? or hard phone?
can you post the debugs here?
partheeban1 Wed, 04/22/2009 - 01:23
Hi gogasca,
Thanks for your response.
I am not using any ip phones or communicator as of now.Just i am using csim start from router to my mobile number. Router has two pri lines from different service providers.when i dial with 1st SP the call is connecting perfectly but when i go for the second pri the call is disconnecting.I have done the same configuration for the both lines.also attached the failed call logs.
