Douglas Hardison Wed, 04/22/2009 - 14:19
  • Cisco Employee,
Best practices will vary widely according to your particular installation.
Cisco IronPort has put together some guidelines that should be helpful, and posted them in the support portal.
http://www.ironport.com/support/login.html
If you login and search the KnowledgeBase for 'best practice', you'll be returned >60 documents regarding various portions of IronPort configuration.
-whardison
