CSA causing BSOD - btaudio.sys
Apr 21st, 2009
Hey Guys,
We're trying to build a new SOE, but on a laptop when you turn on/off bluetooth we recieve a Blue screen of death. With CSA uninstalled the error does not occur. With CSA turned off (right clicked on task bar) we still get a BSOD, so that kinda rules out any rules/policies.
Any ideas without upgrading the server to version 5 or 6? I'm not confident with this software to upgrade.
V4.5.1 build v657
Thanks!
jan.nielsen Wed, 04/22/2009 - 04:20
  • Gold, 750 points or more
btaudio.sys is part of the bluetooth stack for windows, it can be from WIDCOMM or a repackaged version from ibm/ms/dell/hp whatever, i would consider searching for BSOD in regards to the bluetooth driver for that specific platform, otherwise you are looking at a bug, which is not easily solved by changing rules in csa, in 5.x there is a class called "only needing kernel protection", which sometimes can be used, but this sounds like a bad driver, that tries to install itself in the same call tables as csa, and causes a BSOD, so looking into fixing the driver problem, might be simpler and quicker than trying to fix csa.
