04-21-2009 11:06 PM
(CE)--Trunk-port-via.wi-max-device--(PE-Switch)--Trunk port--(PE-Router)
In above scenario suppse CE router is unable to create sub-interface so to communicate with PE router I have used
switchport trunk native vlan 834 and it's working
But when I use
encapsulation dot1Q 834 native on router sub-interface it is not working
##########Working config#################
PE-Switch#
interface FastEthernet1/0/5
switchport trunk allowed vlan 503,834
switchport mode trunk
speed 100
duplex full
PE-Router#
interface GigabitEthernet1/0/1.834
bandwidth 128
ip vrf forwarding ABC
ip address 172.34.63.69 255.255.255.252
end
PE-Router#ping vrf ABC 172.34.63.70
Sending 5, 100-byte ICMP Echos to 172.34.63.70, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/3/4 ms
##########Non-Working config#################
PE-Switch#
speed 100
duplex full
PE-Router#
bandwidth 128
end
Success rate is 0 percent (0/5)
Thanks & Regards
Mahesh
Solved! Go to Solution.
04-22-2009 04:57 PM
I'm confused with your configuration because the switchport trunk native vlan 834 command is gone in your non-working configuration.
Also is Fas1/0/5 connected to your CE or PE-Router.
Let's say Fas1/0/5 is connected to your CE and 1/0/6 to your PE-Router. A working configuration should be:
PE-Switch#
speed 100
duplex full
interface FastEthernet1/0/6
speed 100
duplex full
PE-Router#
bandwidth 128
end
Be sure your native VLAN is consistant on all your trunk or you could have traffic leaking between VLAN 1 (default native VLAN) and VLAN 834
Laurent.
04-22-2009 04:57 PM
PE-Switch#
speed 100
duplex full
speed 100
duplex full
PE-Router#
bandwidth 128
end
Laurent.
04-23-2009 02:45 AM
OK,
Means this is OK for testing purpose. but we should not give this solution to customer. reason is I will be able to define only one vlan as native vlan on one port
anyway man thanks a lot for your valuable time
--Mahesh
