IDSM2 spanning tree
Apr 21st, 2009
what is a default value of spanning tree cost for data port on IDSM2 module?
If we put command
intrusion-detection module 4 data-port 1 spanning-tree cost 1
what is changed?
Anonymous (not verified) Tue, 04/28/2009 - 06:49
[no] intrusion-detection module module_number data-port {1 | 2} spanning-tree cost path_cost
Sets the spanning tree path cost for the data port on the specified module. The no option restores the spanning tree cost for the data port on the specified module to the default cost value.
rhermes Tue, 04/28/2009 - 12:44
  • Gold, 750 points or more
Each link between spanning tree switches has a "cost" associated with the bandwidth of that link. This allows switchs to caculate the lowest "cost" (highest bandwidth) path to the root switch. Here's a table of the STP cost for each bandwidth:
http://en.wikipedia.org/wiki/Spanning_tree_protocol
I think that I shall never see
A graph as lovely as a tree.
A tree which must be sure to span.
So packets can reach every LAN.
First the root must be selected.
By ID, it is elected.
Least cost paths from Root are traced.
In the tree these paths are placed.
A mesh is made by folks like me.
Then bridges find a spanning tree.
- Radia Perlman
