CCNP inquiry
Apr 22nd, 2009
I passed my CCNA 2 years ago and i am now preparing to get at least 1 exam. I have bought the Cisco press CCNP bundle and i would like to ask what is the easiet path to learn/take the exam...should i start with BSCI, BCMSN, ICSW and ONT? or there is a better path?
Would the book and simulation enough to pass or would it be better to attend a cisco learning partner for a higher chance of passing?
thanks in advance
Eduard
eng.taher_gabr Wed, 04/22/2009 - 04:14
Hi Eduard
first good luck for what ever path you will take , but i recommend to start with ccnp because it provide the candidate with very good knowledge then you can start any other path such as ccsp or ccip or ccdp
in case you decide to take ccnp i recommend you to take bsci first
good luck
taher
edongskiu Wed, 04/22/2009 - 18:06
Hi Taher,
thanks for the encouragement.
Is there an advantage on taking bsci first prior to other exams?
regards,
Eduard
ccbootcamp Fri, 04/24/2009 - 07:29
Eduard,
I think you picked a perfect order. It's the EXACT same order we use to teach our CCNP boot camp:
www.ccbootcamp.com/instructor-led-training/ccnp.html')">http://www.ccbootcamp.com/instructor-led-training/ccnp.html
We've gone through the different courses many times and have determined that this is the most effective order to complete the CCNP track. Good luck with your studies! If you have any questions, let me know.
ttyl
Brad
www.ccbootcamp.com
(please rate the post if this helps)
