Logs Cat 4507R
Answered Question
Apr 22nd, 2009
We have a Cat4507r but when I are connected by console or telnet with a monitor console command it doesn't show us any cahnge in the status of its interfaces or any tipe of change that other serie switch show us indeed.
Correct Answer by NickNac79 about 8 years 3 months ago
Some Catalysts - (The 6500&7500 for example) don't by default log Interface changes.
You need to enable the logging of them using "logging event link-status default"
Hope that helps.
Nick
Overall Rating: 4 (2 ratings)
NickNac79 Wed, 04/22/2009 - 02:29
  • Bronze, 100 points or more
Hi There,
Try:
logging console debugging (for console cable)
logging monitor debugging (For ssh connection with "terminal monitor")
Nick
NickNac79 Wed, 04/22/2009 - 05:09
Are you getting absolutely nothing at all, or just not the Interface statuses?
What if you do a debug ip icmp and ping the device?
If you are getting something, then it's just a matter of setting up the correct snmp traps.
Nick
Oscar Cardiel Wed, 04/22/2009 - 05:57
Hi Nick,
We are using SNMP traps and logging traps notifications to get all the manager information but the same configuration is running in other serie Catalysts and they show us console information about port link changing state for exemple.
This is our logging config:
logging trap notifications
logging facility local3
logging source-interface Vlan20
and SNMP config too…
so do you think it is normal in series Catalyst 4500 if you are using snmp and logging traps?
thanks Nick
Oscar
Correct Answer
NickNac79 Wed, 04/22/2009 - 23:44
Hope that helps.
Nick
davy.timmermans Thu, 04/23/2009 - 00:27
  • Silver, 250 points or more
As Nick says with some software releases for certain series it's disabled by default.
I confirm that with cat4500-ipbasek9-mz.122-50.SG1.bin (and probably also with software releases before) you need to enable it globally with the command
logging event link-status global
or you can enable it on an interface basis as you don't want to receive traps/loggings for user ports.
Oscar Cardiel Thu, 04/23/2009 - 05:07
Hi there,
I agreed with all you. I have tried it and it is working in the cat 6500 series, not in 4500 series but I think it is coz the IOS doesn't support the command. I am going to look for the command line for my IOS version.
Thank you very much folks for your help and time.
Kind regards.
Oscar
