PA-MC-8TE1+ card
Answered Question
Apr 22nd, 2009
Hi guys,
I am stuck till yesterday with a new purchase of a 7200 router with a pa-mc_8te1+ card. After starting the router, i have the alarm on the card red and the enable led green.I am not sure if this state is ok as there's at the moment any connection on the e1 ports.
Is That red alarm right ?
Also, i asked to be delivered with a service provider software. But got this one ..."c7200-is-mz.122-15.T14.bin". a Service provider image should be c7200-p..." isn't it?
thanks
Router>sh ver
IOS (tm) 7200 Software (C7200-IS-M), Version 12.2(15)T14, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Sat 28-Aug-04 16:22 by cmong
Image text-base: 0x60008954, data-base: 0x61C02000
ROM: System Bootstrap, Version 12.2(4r)B2, RELEASE SOFTWARE (fc2)
BOOTLDR: 7200 Software (C7200-KBOOT-M), Version 12.3(15b), RELEASE SOFTWARE (fc1
Router uptime is 1 hour, 11 minutes
System image file is "disk0:c7200-is-mz.122-15.T14.bin"
cisco 7206VXR (NPE400) processor (revision B) with 491520K/32768K bytes of memor
y.
Processor board ID 30826591
R7000 CPU at 350Mhz, Implementation 39, Rev 3.3, 256KB L2, 4096KB L3 Cache
6 slot VXR midplane, Version 2.7
Last reset from power-on
Bridging software.
X.25 software, Version 3.0.0.
Primary Rate ISDN software, Version 1.1.
Channelized E1, Version 1.0.
2 FastEthernet/IEEE 802.3 interface(s)
8 Channelized E1/PRI port(s)
125K bytes of non-volatile configuration memory.
47040K bytes of ATA PCMCIA card at slot 0 (Sector size 512 bytes).
8192K bytes of Flash internal SIMM (Sector size 256K).
Router>sh diag
Slot 1:
PA-MC-8TE1 Plus Port adapter, 8 ports
Port adapter is analyzed
Port adapter insertion time 01:17:31 ago
EEPROM contents at hardware discovery:
Hardware Revision : 2.0
PCB Serial Number : JAB06010A9C
Part Number : 73-7549-01
Board Revision : A0
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Deviation Number : 0-0
Product Number : PA-MC-8TE1+
Top Assy. Part Number : 800-19387-01
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 03 4E 41 02 00 C1 8B 4A 41 42 30 36 30
0x10: 31 30 41 39 43 82 49 1D 7D 01 42 41 30 03 00 81
0x20: 00 00 00 00 04 00 80 00 00 00 00 CB 94 50 41 2D
0x30: 4D 43 2D 38 54 45 31 2B 20 20 20 20 20 20 20 20
0x40: 20 C0 46 03 20 00 4B BB 01 FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Correct Answer by Edison Ortiz about 7 years 9 months ago
Overall Rating: 5 (1 ratings)
Edison Ortiz Wed, 04/22/2009 - 06:41
You are correct, Service Provider image is c7200-p-mz.122-15.T14.bin - your current image is just IP Plus.
As for the module, based on the show diag output - it looks to be in good status. I wouldn't be concerned about the LED status until you plug the E1.
__
Edison.
coletemple Wed, 04/22/2009 - 07:54
Many thanks, Edison.
I need to make sure now that the card is ok before signing the order document. I don't have any e1 line at the moment to test on. any idea about how to be sure that the card is ok? is it a normal operation mode for the e1 ports to have the alarm led red before plugging a e1 line?
Cheers
dpothier Wed, 04/22/2009 - 20:44
make sure you configure the card type:
It won't show in the config until
Specify whether the card is to be used as T1 or E1 by using the card type command in
configuration mode.
The example below sets the card in slot 1 to T1:
Router(config)# card type t1 1
The example below sets the card in slot 1 to E1:
Router(config)# card type e1 1
http://www.cisco.com/en/US/docs/interfaces_modules/port_adapters/install_upgrade/multichannel_serial/8-port_multichannel_t1.ei_8pri_install_config/2738cfg.html
coletemple Thu, 04/23/2009 - 00:49
Thanks for the info.
I've configured the card type (e1) already and performed a hard loopback plug test and found everything ok(ping was successful).
I still have the alarm red led on though.
