VPN remote access configuration on asa 5540
Apr 22nd, 2009
Dear All,
when i m configuring my asa 5540 i am not getting option or command to configure vpn tunnel.In ASa configuration mode i m getting no option to configure von.
i.e
asa(conf)#crypto ?
configure mode commands
ca certification authority
key long term operation key
then how i run crypto isampk policy command i am unable to run remote vpn configuration commands in my asa 5540.
I have VPN prmium license.
VPN-DES Enabled.
VPN-3DES-AES enabled
Cisco ASA Software version 7.0
i am also not getting vpn wizard option in ASDM 5.0.
please tell to enable the vpn wizard and how to configure vpn in my asa 5540.
Thank You
JORGE RODRIGUEZ Wed, 04/22/2009 - 04:44
Chetan, it is possible that your firewall is configured as transparent mode - or context? for which vpn is not supported..
or perhaps your user credentials used to administer firewall does not have proper priviledge for those commands?
can you confirm above is no the case, post the output of " show firewall " and confirm you have full admin priviledge to the firewall.
chetansharma Wed, 04/22/2009 - 08:15
Dear sir,
i have checked my firewall mode it is routed mode with multiple context.
and i m login with the user whose privilage level is 15.
JORGE RODRIGUEZ Wed, 04/22/2009 - 11:38
unfortunately there is no VPN support or dynamic routing support for multiple context.
http://www.cisco.com/en/US/docs/security/asa/asa71/configuration/guide/contexts.html#wp1116132
Unsupported Features
Multiple context mode does not support the following features:
•Dynamic routing protocols
Security contexts support only static routes. You cannot enable OSPF or RIP in multiple context mode.
•VPN
•Multicast
