04-22-2009 04:26 AM
Hi, Trying to set up a FAX machine on a 2851 with a VIC/FXS card. It works fine to dial out from the FAX Machine but when I try to dial in it does not work. The EPhone for the FXS card need a MAC adress and i can't find it.
phone 1
device-security-mode none
mac-address xxx.xxx.xxxx
username "FAX"
type anl
button 1:1
Anyone?
Solved! Go to Solution.
04-22-2009 10:30 AM
You don't need ephone for a fax under FXS. Just configure a pots dial-peer with number and port.
04-22-2009 10:30 AM
04-22-2009 11:16 PM
Thank you. That was easy.
!Internal number 740
!Analog fax machine
dial-peer voice 740 pots
destination-pattern 740
port 0/0/0
