Auto RF
Answered Question
Apr 22nd, 2009
We just setup auto RF on all of our 12 controllers. My question is, is the controller group leader the only controller
that will display the "Last Group Updates" times? or should I see it on all the controllers?
Correct Answer by jeff.kish about 7 years 9 months ago
You should see it on all controllers. Each controller has its own timer for running the Auto RF checks.
As an aside, I highly recommend that you disable the automatic updates. Running them manually once a week or so is usually best, unless you have a constantly changing or challenging environment. Client can occasionally be disconnected by the automatic updates, which occur every 10 minutes by default.
Correct Answer
jeff.kish Wed, 04/22/2009 - 05:23
frmejiugr Mon, 11/16/2009 - 01:29
Hello.
We have the same problem: 6 controllers running 4.2.207 and only one (controller group leader) shows actualizations. Any body knows what is the reason?
Thanks in advance.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
