Employee and "hotspot" ssids
Apr 22nd, 2009
Greetings,
Trying to set up both an Employee and Hotspot ssid connection. The Hotspot is working fine. The Employee is not broadcasting SSID (by design) and will not connect from a manually configured preferred network entry. Also - Dot11Radio0 interface is working - Dot11Radio1 is in reset mode. Can someone please take a look at the attached config and to see where I'm going wrong?
gamccall Wed, 04/22/2009 - 10:46
  • Silver, 250 points or more
Well, one fix that jumps out at me is:
int d0
no encryption mode ciphers aes-ccm tkip
encryption vlan 2 mode ciphers aes-ccm tkip
IIRC, I believe a radio may go into reset mode if it has no clients on it. Try connecting on A (once you have G working properly) and see if that works.
Trending Topics - Security & Network
