Help with VPN to ASA 5520
Apr 22nd, 2009
I have a Cisco 2621 router that is required to be used as a VPN between to a Cisco ASA.
Below I have started to build the config on the router, but have stalled. I can ping the peer address of the firewall and have been told the ASA is all configured. I have set up VPN's using a DSL router like an 877 to a ASA before but not a 2621 ethernet based router.
ASA is 192.168.82.5 (example peer)
My crypto map MYCRYPTOMAP is not bound to an interface yet, would this need to go on the FE0/0 (outside)
I'm sure there are many gaps to be added.
C2621XM#sh run
Building configuration...
Current configuration : 1350 bytes
version 12.3
hostname C2621XM
boot-start-marker
boot-end-marker
logging buffered 8192 notifications
no network-clock-participate slot 1
no network-clock-participate wic 0
no aaa new-model
ip subnet-zero
ip cef
no ip domain lookup
ip dhcp excluded-address 10.10.10.1 10.10.10.10
ip dhcp pool LAN
network 10.10.10.0 255.255.255.0
default-router 10.10.10.1
crypto isakmp policy 1
encr aes 256
authentication pre-share
group 5
crypto isakmp key tottenham address 192.168.82.5
crypto ipsec transform-set MYSET esp-aes 256 esp-sha-hmac
crypto map MYCRYPTOMAP 1 ipsec-isakmp
set peer 192.168.82.5
set security-association lifetime seconds 86400
set transform-set MYSET
set pfs group5
match address 100
interface FastEthernet0/0
ip address 192.168.82.6 255.255.255.240
duplex auto
speed auto
interface FastEthernet0/1
ip address 10.10.10.1 255.255.255.0
duplex auto
speed auto
ip http server
no ip http secure-server
ip classless
logging trap notifications
access-list 100 permit ip 10.10.10.0 0.0.0.255 any
line con 0
password cisco
logging synchronous
line aux 0
line vty 0 4
password ****
logging synchronous
login
end
C2621XM#
Ivan Martinon Wed, 04/22/2009 - 09:49
Are you sure this settings match the ASA? PFS? match address? does the ASA have any as the source for this tunnel? Can you enabled ipsec and isakmp debugs and post them here?
whiteford Wed, 04/22/2009 - 11:02
They do seem to match, well I am told they do as I don't control the ASA which is another company.
The only thing I haven't done is bind my crypto map "MYCRYPTOMAP" to anything, what interface should I bind this too, as I have only ever worked with DSL routers like the 877 and I bind these cryptomaps to the dialer interface.
Ivan Martinon Wed, 04/22/2009 - 12:20
Yeah you need to apply the crypto map to the interface that connects to interface.
