ATA vs VG202 vs VIC3-2FXS-E/DID & Wireless
Apr 22nd, 2009
What is best solution moving forward?
Fax server probably two years out.
I have 34 locations
30 locations have 2 analog devices
4 Operations have 26, 14, 15, 10 analog devices
Currently we use ATA 188 and 186 and one VIC2-2FXS
We Have intermittent problems receiving faxes from Fax servers or other customers in general.
Overall Rating: 5 (1 ratings)
Nicholas Matthews Wed, 04/22/2009 - 06:20
The VG20x are nice because you can use them as a full blown router (VPN, IGP, etc).
I think you'll have more cost per port using a VIC3 rather than VG204. Their capabilities will be equal, as opposed to when the ATAs were in use.
The ATAs are on their way out, and I think you'll find the VG20x to be an easier product to use and it will work better with faxes/modems. The ATAs don't have great fax/modem support where the VG20x will have T38 support and modem support.
For the locations with 15+ devices it may be worth looking into the VG224 as well, depending on usage.
